Old 02-19-2007, 06:33 AM
Bad94 Bad94 is offline
Default Max RPM for LT1 computer?
What is the Max RPM is a LT1 computer good for?
Im looking into building a 302 LT1 for my project. But if the stock LT1 computer isnt good for aleast 8000 RPM im not going to build it.
Thanks Dan
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 02-19-2007, 10:17 AM
Derek69SS's Avatar
Most figures I've heard for them are in the 7000 - 7200 max range
I'm guessing you must not be building a "street" engine if you're looking for 8,000rpm???
Old 02-20-2007, 07:02 AM
Dave95z28 Dave95z28 is offline
Like he said 7000-7200 RPM is as high as the computer can handle. Ed Wright has played the computer programming extensively in order to find a way around it with his low 10.00 NA Trans Am.
I my last project was going to be 500+ RWHP NA 392 LT1 with AFR 227s, single plane intake and huge solid roller but I have decided to part it out now, to focus on my 69 Camaro. To get around the limitations of the factory computer I bought a FAST ECM and wiring harness that piggybacks the factory PCM.
Dave
