Old 03-01-2007, 03:04 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default What do you think? Suspension.
ok Guys, what do you think of this combination. It's going in a 69 camaro convertibel 454. Hotckins TVS System, Global West upper and lower control arms,QAI Shocks. will I ride smooth and hanlde well?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 03-01-2007, 07:27 PM
jsconiers jsconiers is offline
Have you looked at the g-bar from ca.
Old 03-01-2007, 08:39 PM
bigtyme1's Avatar
never heard of it
69 RS Ragtop
[email protected]
Old 03-01-2007, 08:50 PM
Look into it....Its very nice and one of the best setups I've seen up close and personal. I have not used the tvs system but if you do a search you should find some info.
never heard of it
Old 03-01-2007, 08:56 PM
TravisB TravisB is offline
it is the same as the airbar without the airbags
Kenny Davis Hot Rods
Old 03-01-2007, 09:07 PM
bigtyme1's Avatar
looks great, but it's not in the budjet. YET!
69 RS Ragtop
[email protected]
Old 03-03-2007, 07:18 PM
bigtyme1's Avatar
So anyway, what do you think of the combination. Also will I have any problems with the hotchin front sway bar and the global west control arms?
69 RS Ragtop
[email protected]
Old 03-05-2007, 02:32 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
The TVS springs and bars should be fine. GW arms are nice and you`ll get better bushings and a little more + caster. No real geometry change though so gains there will be very small. I`d suggest either doing some version of the G mod,running our tall ball joints with the GM arms or one of our StreetComp ball joint/adj. upper arm packages. AFX tall spindles would also do the trick very nicely. BTW the more you improve the front suspension geometry the less you need (or want) a huge "bandaid" front swaybar. In our experience (customer cars and our own) QA1 shocks can be a little spotty. We`ve had problems with leaking,bushings and inconsistent adj. settings. For a few more bucks you can upgrade to Alston Varishock QS1 16way adj. shocks. Overall quality is much better and the adj. are very reliable and repeatable. Mark SC&C
Old 03-05-2007, 02:55 PM
We just started selling Hotchkis in December and sold a bunch of TVS set ups. So far everyone has been real happy. We just did a 69 Camaro convertible with the full TVS kit and it was sweet. For the money you cannot beat it. The Hotchkis shock is also very nice, especially for the money on a tight budget. You will spend a couple hundred less then QA1s, but give up the adjustability.
Today, in the shop, I have a 67 Chevelle getting a TVS system and aftermarket upper and lower arms. I am doing a install story and driving test before and after as this was a nice driving rebuilt, urethane bushing car before we dismembered it. I will have the story up in a couple weeks.
I am a big fan of the TVS kit on a budget.
Frank Serafine
