Old 03-02-2007, 08:14 AM
melman109's Avatar
melman109 melman109 is offline
Default I need some help!
Well I called a body shop to get some work done on my 68 Camaro, and I was told that I needed to remove the rear suspension and the sub frame in order for them to appy the rhino coating.... I need to know how to build one of those dollies that holds the body up on casters, or where I could buy one
here's an example of what i'm looking for.
Old 03-02-2007, 03:45 PM
Musclerodz's Avatar
You have the pics right there. It attaches to the front sub connector and the front leaf bracket
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 03-03-2007, 07:21 PM
almcbri's Avatar
almcbri almcbri is offline
I used 3" square tubing for my body cart. Eastwood sells them, and right now eastwood has free shipping until Monday I believe.
I would build the cart to be a bit taller than the pics you have, or make it adjustable with pins, so you can raise the heights.
there isn't much to it, just a little measuring, cutting, and welding. I made mine adjustable for a variety of cars. good luck
Old 03-06-2007, 07:16 AM
melman109's Avatar
Thanks andrew!! Thats exactly what I was looking for
Old 03-06-2007, 08:32 AM
T Bell T Bell is offline
one question, how will they Rhino line the area that the attachment point covers up. I am thinking about having mine done and was thinking of using 4x4 pretreated lumber (I have it available) and casters similar to the angle iron.
Old 03-06-2007, 08:57 AM
almcbri's Avatar
The points that are attached, like in the pictures above are covered anyways by the subframe and by the leaf spring shackles. When I had my car sprayed I had it mounted on a rotisserie, and after I got it off I sprayed the mounting point areas that didn't get covered w/ a heavy coat of black paint.
One thing to consider when having your car rhinolined, is to apply a good coat of primer. I wouldn't just apply the bed liner material to bare metal.
