Old 03-03-2007, 04:09 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Default Batteries draining
Well I went out this morning and found both my batteries dead. I'm not sure, but I might have left the switch on to connect them together while the ignition is off. I have the painless switch that lets you combine the two either when the ignition is on or off.
Anyhow, I charged the main battery back up and was able to drive, and everything seemed ok. When I got back home, I went to investigate, and put a voltmeter on the auxillary battery. I could see the voltage drop... 10.75...10.74....10.73.... I thought maybe something was shorting, so I pulled off the cables. Well, the battery kept dropping voltage, with nothing else connected. It's an Optima Yellow Top. This doesn't sound right, does it? Could the battery have a problem?
-Tom
camarorestoration.com
Old 03-03-2007, 04:23 PM
philofab's Avatar
philofab philofab is offline
Let the battery sit for a few days and then charge it with a heavy duty charger for about 6 hours. Then let it sit for another day and check voltage. If it's below 12 volts its no good. I can usally get redtops to come back this way.
I like old junk and have ADD.
Old 03-03-2007, 04:24 PM
philofab's Avatar
Oh, that switch shouldn't discharge your battery in any position.
Old 03-03-2007, 10:48 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Look into a charger/maintenance from www.ctek.de
www.hotrodderjournal.com
Old 03-13-2007, 12:54 AM
71Nova 71Nova is offline
Tom I had a red top go bad after forgetting that the key was on for about a week. It refused to take a charge and the charger acually said the battery was no good. After a few failed attempts at charging I switched the charger to jump start mode for about 5 min. Shocks the crap out of the battery. I guess it taught it a lesson because it charged fine after that and I have been using the same battery for about a year now with no more problems. I heard that if you have a cell reverse giving it a high current shock can flip the cell back. Yours sounds like a different problem considering it is charging, but slowly discharging itself. Sounds like it eather did not charge fully when you charged it, or the battery is just bad.
David
Old 03-13-2007, 09:54 AM
rockdogz's Avatar
I got the yellow top replaced at Costco, and so far so good...
-Tom
