Old 03-05-2007, 05:50 PM
InMotionJosh InMotionJosh is offline
Default What Gear Ratio?
I am needing to order my new currie 9 inch for my 70 chevelle but am not sure which gears to go with. I am going to be running either a 408 or 427 LSX motor N/A. Its going to be backed with a 4l80e transmission. I need to figure out what gear ratio to order though. I plan to use a 28 inch tire and would like this car to be good on the highway and on the street. Id like a good balance of performance for both. i was thinking maybe a 3.42 or 3.55 would be a nice choice. Any thoughts?
Old 03-05-2007, 06:01 PM
We sell a bunch of Moser rears and use a lot of 3.50 gears in Fords. You can also get away with a 3.70 gear and get a little more snap out of the hole and only give up a little bit of RPM on the Hwy.
The 9" is a good rear end, but have you though about a 12 bolt? For the same money you can have a 33 spline True Trac 12 bolt with a performance cover that is stronger then a 31 spline True trac 9" and the 12 bolt does not steal horsepower. Were selling more and more 12 bolts since the 33 spline True Tracs came out.
Frank Serafine
Old 03-05-2007, 06:03 PM
I have not really looked into a 12 bolt at all. You say it uses less power than a 9 inch? I think the car is going to have traction problems on the street anyway so too much snap out of the hole wont be helping much.
PM me with a price for a fully built bolt in 12 bolt for a 70 chevelle with gears etc....im in the market ASAP!
Old 03-05-2007, 06:16 PM
chicane's Avatar
chicane chicane is offline
I say 3.70's (or 3.73's for the 12 bolt) with a 28" tire.
Old 04-02-2007, 08:53 PM
pdq67 pdq67 is offline
Thumbs up
He, He!!
Imho, a Chevelle need's a GM 12-bolt under her and I bet that you would dearly love the 3.31's IF you can find a good used set, otherwise use 3.42's!!!
And again, imho, no lower than 3.73's!!
That said, a 9" w/ 3.50's should do you well.
pdq67
