Old 03-08-2007, 08:27 AM
DarKnight's Avatar
DarKnight DarKnight is offline
Default Hyperuetic pistons for sub-500 hp ?
hey guys
Just looking into Scat 9000 rotating assemblies. i just need some thoughts on hyper pistons for 400-450 hp and about the same torque.
I want to build a 383 for my daily driver Monte.
I'm Justin Rozs and I approve this message.
http://pg.photos.yahoo.com/ph/justin...1a12re2.jpg&.s
Old 03-08-2007, 10:56 AM
deuce_454's Avatar
fur applications in that power level hypereutectics are great.. they also polish nicely on the piston top to keep some extra heat in the chambers and retain some free horsepower..
you can also install them backwards, that way you gain some top dwell (poor mans long rod engine) drawback is added noise but its also free ponies..
Jake: Hit it.
Old 03-09-2007, 04:54 AM
DarKnight's Avatar
Thats cool. so the hypers have some benefit other than being cheap?
what do you think of Scat 9000 rotating assemblies? anyone with any experiance with them?
Old 03-19-2007, 07:06 PM
kilrcam kilrcam is offline
I have a scat 9000 rot assem. in my camaro (355 sbc) with hyper pistons i'm running about 475 hp on motor and i spray it with a 200 shot. I don't drive the car much but when i do take it out and run it i'm not nice on it and it's been together since 2003. So far so good. Also i'm running a scat 9000 pro comp light weight crank in my chevelle (406 sbc) thats pushing close to 650 on motor rods and pistons are forged but again i have a 100 shot on it. Might be pushing the limits there but it's held together for a year now without problems.
91 camaro RS, 70 chevelle, 99 dodge dakota,
62 thunderbird, and 89 cougar
No Sympathy Racing
No sympathy for the loser
http://img.photobucket.com/albums/v6...marodakota.jpg http://img.photobucket.com/albums/v6...o/DSC00314.jpg
Old 03-20-2007, 06:08 AM
DarKnight's Avatar
Thats what i wanted to hear. Someone thats running in the power i want with that set-up.
Thanx Kilr.
Old 03-20-2007, 06:42 PM
No problem. Just make sure you have it balanced by someone trusted. And make sure your tune is good detonation will cause problems.
No Sympathy Racing
