Old 03-12-2007, 11:15 AM
BThibodeaux BThibodeaux is offline
Default Anyone run plug wires underneath headers on a BBC?
I want my engine compartment to look as clean as possible, so I plan to run the plug wires underneath the headers on my BBC build. Has anyone done this? If so, can you share some pics and give me some pointers? Thanks.
Brian T.
2011 Chevrolet Camaro Convertible
Old 03-14-2007, 10:21 AM
HRBS's Avatar
HRBS HRBS is offline
Run them underneath from behind and use wire seperators. By using 8.5 wires the combonation of "stiffness" and seperators will hold them in place under the tubes. It also depends on what type of header you use. The orange car had full tube headers and the green car had block huggers. It is nearly impossible to do with the block huggers because of the tube configuration.
Note the difference here:
Tucked under and hidden:
Run down the side of the valve cover but on top of the headers:
HRBS on Facebook
Old 03-15-2007, 01:48 PM
[QUOTE=HRBS]Run them underneath from behind and use wire seperators. By using 8.5 wires the combonation of "stiffness" and seperators will hold them in place under the tubes. It also depends on what type of header you use. The orange car had full tube headers and the green car had block huggers. It is nearly impossible to do with the block huggers because of the tube configuration.
Thanks Steve, both look great! I will be running mid length headers. Hopefully I will have the room to run them underneath.
Brian T.
Old 03-15-2007, 05:28 PM
Fotoboy Fotoboy is offline
Old 03-16-2007, 12:24 PM
ProTouring442's Avatar
Sweet! I'm guessing you purchased a "terminate your own" kit, or does someone make them like that?
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442
Old 03-16-2007, 04:20 PM
HRBS's Avatar
Absolutely.... otherwise you'd never be able to snake them around that long of a distance.
HRBS on Facebook
Old 03-18-2007, 09:30 AM
James OLC's Avatar
There are BBC plug wire kits available that are ideal for under header applications. Like in Fotoboy's application, the MSD HP500EFI kit is designed to be run under the headers and the lengths are perfect. When I ran my plug wires under the headers, I was using motor plates and kept them tight to the block using a mount off the stock motor mount bolt holes. I was using coated Casler headers and never had any problems with burnt boots.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 03-21-2007, 09:13 AM
Thanks. I will check out the MSD kit. Coated headers are definitely the way to go.
Brian T.
Old 04-02-2007, 12:22 PM
Easy,just take your time to make it right and mount all wires for good.
Sorry for low quality pic-its sooooo old
63 Z06
Old 04-06-2007, 06:48 PM
Steve68 Steve68 is offline
I did it and set my brand new MSD wires on FIRE!!!
