Old 03-12-2007, 01:36 PM
jsconiers jsconiers is offline
Default ls1 brake conversion on rear of 68 firebird
If I use ls1 rear brakes on a 10 or 12 bolt of a 68 firebird are there any modifications required? IE relocating shocks, using two right hand brakes, etc.
Old 03-12-2007, 05:00 PM
GM Muscle's Avatar
as far as i understand if you have staggered shocks you need to two rights... and you will need to make new brake lines..
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 03-13-2007, 08:02 PM
Hammered's Avatar
Hammered Hammered is offline
I think that if you use the LS1 backing plate with C5 rotors and calipers, you can avoid the shock interference issue. The calipers get moved outboard about 1". Of course this could cause wheel clearance issues.
1967 Firebird Convertible, 462, EFI, TKO
My Firebird
Old 03-13-2007, 08:25 PM
hifi875's Avatar
hifi875 hifi875 is offline
Default ls1 upgrade 1st gen camaro
is there a article outthere that goes over what you need to do a ls1 front rear upgrade?
