Old 03-13-2007, 01:47 PM
fletcherscustoms fletcherscustoms is offline
Default DSE Speed 3 front kit, ATS motor mounts, Custom stock subframe, Marquez lights
Alright guys got to part with some stuff as I am changing plans on the "Aftermath" build
1) Detroit Speed Speed 3 front Suspension kit
DSE uppers and lower,Koni coilovers and springs, sway bar, DSE 600 Steering box with Pitman and rag joint, Tie rod adjusters, inner and outer tie rod ends. Everything included in the normal Speed 3 kit minus the Coilover frame mounts, as they are already welded to my subframe for sale below.
$2900 shipped all brand new still in the box from DSE
2)Stock Subframe from 69 camaro, straight, has been modified for DSE coilovers with the weld on brackets, also all seems have been welded and plated and ground smooth to give the frame the appearance of being a one piece unit. It is in primer and will need a few hours of body work and sanding before paint.
$1400 plus shipping of $4500 shipped with Speed 3 kit above
3) ATS LSX engine mount plates and Poly motor mount bushings
$160.00 shipped, new in box from ATS
4) Marquez Design front Billet Marker lights
$65 shipped, new in box from Marquez
Everything together $4700 shipped
Edit/Delete Message
Old 03-14-2007, 05:46 PM
Kevin Kevin is offline
Default Marquesz Lights
Are the Marquez Design front Billet Marker lights you meantioned the Billet Turn Signal/Parking Lights with LED lighting to 69 Camaros?
If they are please call me at 770-655-0423
Thanks,
Kevin
