Old 03-17-2007, 09:03 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Default rack and pinion ?
I was just wondering how much if any modification is req. on a stock sub frame (72 Nova)to get the rack&pinion and ls-1 out of a 4th gen camaro to fit up
Old 03-17-2007, 10:03 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Give Phil at BRP Hot Rods a call. He's very knowledgeable with this conversion and sells the conversion kits.
Old 03-18-2007, 05:40 AM
98ssnova's Avatar
Thank's I'll do that
Old 03-18-2007, 01:21 PM
71Nova 71Nova is offline
Just be carefull. A lot of the conversion kits hang really low. Not much ground clearance if your Nova is lowered. Sub frames that are designed for rack and pinion do not seem to have the same problem.
David
