Old 03-25-2007, 11:00 PM
drphibes's Avatar
drphibes drphibes is offline
Default What is largest size tire with DSE components
Does anyone know what the largest size tires you can fit with the DSE front subframe as well as the DSE Quadralink and DSE mini tubs on a 1969 Camaro?
Old 03-26-2007, 02:36 AM
tyoneal's Avatar
tyoneal tyoneal is offline
This was straight from DSE: (Front Wheels and Tires only!)
18 X 10
275/40/18 6.125 back space
17 X 9
275/40/17 5 3/8 back space
These are the largest without rubbing, if I remember correctly.
You might want to call to re affirm, however if I wrote my notes correctly, you will find this accurate.
tyoneal
Old 03-26-2007, 08:37 AM
camcojb camcojb is offline
on the rear, the Quadralink will allow 345/30's. If you minitub but retain the leaf springs the 345's are too tight, need to step back to a 335.
