Old 03-26-2007, 01:41 AM
holschen's Avatar
holschen holschen is offline
Default pics on 265/25-20 tires
Hi all looking for pics on 265/25-20 and 265/30-19 tires and possible wheels for the same.
I´m thinking 265 front and 285 rear for now I´ll tub later to fit 325/25-20
I´ve bougt movit brakes front 15" 380mm total 16,5" 418mm with caliper
just thinking about what will fit best 19 or 20"wheels
Old 03-26-2007, 03:14 AM
Those are some serious rubberband tires your talking about there. I would be surpised if you find any of those tires here. I would suggest at least a 26" tire on a 19" wheel, and at least a 27" tire on a 20" wheel
Frank Serafine
Old 03-26-2007, 03:56 AM
holschen's Avatar
Hi Frank
Yea I like rubberbands i found some at a store here in sweden at 300$ a piece
Hankook - Ventus K-107 ZR/YR |265/25-20"
And u get close to the oe at 648mm
The hankook is 640mm 265/30 is 667mm
And u are less likely to rub
Proper wheel would be like 8.5-10"
I found some nice 20"-9" front and some 20"-10.5"rear
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
