Old 03-26-2007, 01:44 PM
Robert Youngfleisch's Avatar
Robert Youngfleisch Robert Youngfleisch is offline
Question hotchkis trailing arms
Hello
i am building a 68 Chevelle. It a frame off resto.
I install the suspension with the body of the frame, in the rear I used hotchkis rear suspension kit (upper & lower control arms, trailing arms, swaybar & coils) when i put the body back on the frame the trailing arms are touching the body.
Does any one know if this is supposed to do that?
Thanks in advanced
Old 03-26-2007, 02:02 PM
deuce_454's Avatar
here is a dumb but obvious question.... do you have the body mount bushings inatalled, and are they stock height or worn down?
Jake: Hit it.
Old 03-26-2007, 05:32 PM
Brand new & stock height
Old 03-27-2007, 01:40 PM
nbecker nbecker is offline
Can you get pics so we can see the problem,
Old 03-27-2007, 04:28 PM
Here is a picture. Hope you can see what i am talking about
Old 03-28-2007, 05:52 AM
nitrorocket's Avatar
If your sure the body is in the correct location, I would take a pipe in the same area, and hammer it into that area of the floor pan to make the necessary clearance.
Nothing ever fits my car without custom fab work either.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 03-28-2007, 08:06 AM
The pieces that you marked are the supports for the trailing arms,I would call there tech to see what the typical clearance is on those and make sure the body is lined up good
