Old 03-29-2007, 09:11 PM
slyck68 slyck68 is offline
Default Satin valve cover breathers
I recently installed a trick set of fabricated valve covers with a satin finish. I couldn't be happier with the look it gives the engine, however I cannot find matching valve cover breathers anywhere. Does anyone know of any breathers with a satin finish or even a brushed finish? Looks pretty redneck with the polished ones I've got now!
Old 03-30-2007, 06:51 PM
pushrod243's Avatar
pushrod243 pushrod243 is offline
Why dont you just hit the ones you have with scotchbrite? If you use a linear pattern they look just like brushed and scotchbrite is cheap.....
John
Old 03-30-2007, 07:51 PM
1 fine 69 1 fine 69 is offline
i have a set of really nice fabbed aluminum valve covers as well and i just went with k&n air filter style ones to match my air cleaner....turned out really well. i had the same problem as you and it made the bay look much nicer when i changed it all. check out my cardomain website and you will see.last two pics. hope that helped
1969 Camaro SS aka Jumpin Jack Flash
World All Aluminum 427 and tko-600 attached to that
http://www.cardomain.com/ride/2305230/1
