Old 03-31-2007, 01:35 PM
johnny rockett johnny rockett is offline
Banned
Default Gen 1 mechanical linkage LS1
Can anybody tell me if there is an adaptor offered to retain the mechanical linkage of a gen 1 camaro to the lSX serires of engines. I want to use the TKO 600 behind the LS1 but retain the mechanical linkage of my 67 Camaro.
Thanks in advance for the ideas.
Old 04-08-2007, 11:34 AM
JimM JimM is offline
kinda old post, hope you're still looking for an answer...
I just been through a question and answer on another site about this.
LSX motors in fourthgen Camaro's have a cable linkage, just use that throttle body. Lokar has a cable kit. A firstgen Camaro with a 6 cylinder motor has a gas pedal made for a cable, as does 70 and newer Nova's. Put em all togther and you have an LSX without drive ny wire in a firstgen.
Forget the stock linkage rod. Even if you could get it over or thru the LSX manifold, it's looks would leave a bit to be desired.
Webmaster (lol)
68 Camaro Vert, SS clone, #'s matching 383-TKO500
04 Silverado SS, 93 Polo Green Vette
My Camaro Board
http://www.Jimragtop.com
Jim's Blog!
Old 04-08-2007, 12:04 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Jim: I think, based on his mentioning that he's got the TKO600, that he's referring to a mechanical clutch linkage.
To answer the question, yes, both Lakewood and McLeod make bellhousings that should bolt to the LSx engine and your TKO. You'll have to fabicate an inner Z bar mounting point (the LSx's don't have one), likely shorten the Z bar, and maybe play with the clutch fork pivot height to get the geometry right depnding on where your LSx motor mounts put the engine.
Old 04-09-2007, 06:08 AM
Banned
Default Thanks
Well actually both you guys have helped......I was referring to the mechanical clutch linkage. I figured something could be fabbed but with the popularity of these first gen's I thought maybe there was somebody fabing something already.
Thanks again!
