Old 04-02-2007, 06:28 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Need some Leaf spring help!
Hello, I have a set of DSE 2' drop leaf springs on a 67 camaro. I have them installed and the right side sits over an inch lower then the right. Is there something I need to do to make both sides level? Oh by the way, when I installed them I have never done it before so any help would be great seening that im a noob to this. Thanks for your time!
-Brian
WicKeD
Old 04-02-2007, 08:36 PM
pdq67 pdq67 is offline
Smile
Raise her back off the ground and loosen everything up, then set her back down, bounce her a couple to three times and tighten her back up and see if that doesn't level her up.
And I mean everything, shocks, both leaf spring bushing bolts and the "U"-bolts.
Usually they can bind if tightened unevenly up in the air and I have yet to do this to mine too.
pdq67
Old 04-02-2007, 08:53 PM
WicKeD_SS's Avatar
Sweet, ill try that tomorrow or wed for sure. Thanks for the help, hope it works!
WicKeD
Old 05-20-2007, 02:13 PM
WicKeD_SS's Avatar
Ok, I took her up and loosen everything up. Droped her back down, did the jump in the trunk and jump thing. Its still siting almost exactly 1 inch higer on the drivers side. What else should I do? Do you think I could have gotten one two diff leaf springs? one 2 inch drop and the other 3 inch? Dont know If I should call DSE or not.
Any comments would be so helpful!
Thanks guys!
-Brian
WicKeD
