Old 04-07-2007, 08:07 PM
jsconiers jsconiers is offline
Default What wheels with 1st gen f-body & ls1 brake conversion
Converted my front brakes to ls1 brakes and will convert my rear pretty soon. Stock 99 Camaro rims will not fit (and are for sale by the way). They are hitting my tubular control arms. What wheels (with specs if possible) are you running with your ls1 brake swap even they are just temps?
Old 04-08-2007, 06:12 AM
GeoffP GeoffP is offline
I have the LS1 brakes on my 87. Based on this, I'd guess you need to have around 1/4" more offset built into whatever wheel you choose in order to maintain the original offset (if that's what you're shooting for). I think most folks suggest 5.5" backspacing for 1st gens with OE brake setups. (this is what I used for my car with OE front drum brakes).
Hth
GeoffP
68 Camaro LT1/T56
87 Camaro LT1/4L60E
Old 04-08-2007, 02:51 PM
GM Muscle's Avatar
kinda off topic but what master cylinder and booster are you using with your ls1 brakes? im running stock c5 corvette wheels with a spacer right now. .you could probably buy a spacer to move your camaro wheels out..
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 04-08-2007, 05:21 PM
I'm running a Hydra boost unit out of a 99 mustang (used the master and booster). It works great but I don't have it permanently in place right now. I was going to go with a fourth gen master and booster as that unit works well too. I still have the fourth gen unit if you need one.
Old 05-19-2007, 10:00 AM
hifi875's Avatar
hifi875 hifi875 is offline
Default ls1 brakes/wheel combo
i have ls1 fr/rr setup on my 69. 18x7 w/225/40 fronts. 20x8.5 w/255/35 on rear w/no problems. i had 235/40 on 18x8 up front b/4 the swap but changed because i thought there would be issues, but i believe they would work.
Old 06-01-2007, 11:36 AM
D Rock D Rock is offline
I have some spacers that I will let go fairly cheap that will work for corvette wheels, not sure about camaro wheels. Fronts are 1.25 and rears are 1.75. You can measure and see if they would be in the ballpark.
