Old 04-10-2007, 08:37 PM
GM Muscle's Avatar
Default garage sale!
i need room on my shelves.. there are all kinds of parts through out the list. be sure to look all the way through. all parts do not include shipping.. any pics and or addtional info can be retrieved. thanks..
brantley
chrome edlebrock valve covers, sbc, one breather per valve cover, grabb some steel wool and bling them up- $20
flat black tall sbc vavle covers with daul chrome breathers $30
Hooker long tube sbc headers, 67-81 Camaro;65-89 Full Size;64-87 Chevelle,El Camino;70-87 Monte Carlo;68-79 Nova;78-81 Firebird,Trans Am; 78-87 Cutlass,442,Regal 265-400
1-5/8"x30"Primary Tubes
3"Collector , have damage from bottoming out, can be fixed $30
Hedman long tube sbc headers, big primaries, Chevelle,
Malibu,
1964-77,
283-400 ci.,
1-3/4'' Tubing, 3'' Collector
brand new never been ran just installed and moved around.. will mostlikely fit other gm cars SOLD
gm 993 heads, factory castings, virgins! need rebuilding $125
gm 882 heads, factory castings, machined for screw in studs, 202/160 valves, spring pockets have been cut as well, less than 500 miles on them will take $250
crane gold 1.6 roller rockers, self aligning have been ground for bigger springs and retainers, i drove a few hundred miles on them with no problems SOLD
gm th350, shift kit installed, works fine when the temp is above 40, pulses from 2nd to 3rd at a 30mph cruise, could probably use a rebuild $75
gm serpentine setup- mounts the acc right in front of the head not above, brand new alternator and powersteering pump and used ac compressor included comes with everything thing but the waterpump pulley (i used an electric waterpump) $250
2002 ls1 camaro radiator, condensor and daul electric fans, like new condtion $100
passenger 1/4 panel for 93-2002 camaro, brand new, few dents from laying around $50
holley 750 dual feed carb, missing the choke plate $100
98gsx limited seadoo, 142hp, blown motor and the hull needs a small cracked finished out, has already been fiberglassed just needs to be ground and gelled. clean title $400 and will throw the trailor in for an extra $100
chrome airgate for 88-98 gm truck, well used $20
various reciever hitches for something.. looks to be a small suv, i have about 10 of them.. $10 each.. i can take measurents if needed..
one set of taylor spark plug wires, hei style cap and 120 degree boots, black in color built to go over a tall sbc valve cover never been ran only installed $50
aftermarket ricer front bumper for mid 90's honda.. needs some attention.. $30
1968 chevy pu 12bolt, 6 lug, drum brakes $75
factory first gen camaro/nova front springs, sbc, have been cut, will lower the car approx 2" $20
hei dist cap, coil and cover- all parts were purchased new 3 months ago
$30
airlift 1000 air bag kit, they mount in side the coil spring, add air to stiffen the spring rate, brand new in the box $20
new engergy suspension sbc motor mounts black in color.. installed but never used.. 1968-72 General Motors Cars
Black
Zinc Finish
2-3/8'' Width x 2-3/16'' Height
$25
weiand intake
Action +Plus Intake Manifold
1957-86 262-400ci
1987-Up with aluminum heads
Universal Carb Flange
Idle-6000 RPM Range
$75
remanufactored quadrajet carb sbc calibration
$100
chrome moroso valve cover hold downs and t's, extremely thick hold downs and t bars.. the tbars are a one peice design. $25 for a complete set
factory springs struts, and shocks from a 94 formula firebird front and rear 40k miles, $40
powder coat black centerbolt vavle covers with k&n breather $50
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 04-11-2007, 12:26 AM
68Camaro 68Camaro is offline
Default Headers
Do you have a part number on the 1 3/4 headers?
Jared
Old 04-11-2007, 06:46 AM
GM Muscle's Avatar
i will go check them and see if i can find one.. i throw a pic up too.. it will probably be around 7ish
Old 04-13-2007, 12:16 PM
jzzymf jzzymf is offline
Are you willing to part out the cooling fans & shroud ?
If do what do you want for them and the shroud ?
Old 04-13-2007, 08:30 PM
GM Muscle's Avatar
i think the 150 is a fair enough price for the fans.. it is a one peice unit with two fans.. if i did split them up it would still be 150 and id just take the radiator and condensor for scrap..
also i havent got a chance to look at the header part number yet.. im pretty sure they are the ones in jegs that have the same description that i posted..
Old 04-14-2007, 12:04 PM
GM Muscle's Avatar
new prices.. can post pics on request
Old 04-15-2007, 07:32 PM
Default Headers
Do you know if those headers will fit a first gen. Camaro?
Old 04-15-2007, 11:40 PM
GM Muscle's Avatar
ill see if they fit in my 69 probably tomorrow.. thanks..
