Old 04-28-2005, 06:43 AM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
Default wiring kits
Just curious what kits you guys are using for wiring up your cars. I've used Ron Francis and Painless on past projects....... Has anybody used American Auto Wire? Anyway, would like to hear what your using and if you would use that kit again. THANKS!
Old 04-28-2005, 07:25 AM
shanekennedy shanekennedy is offline
i've ordered the AA kit, but haven't received it yet. got it 20% off thru classic-industries recent sale. from what i've read it includes most of the connectors already attached providing for an easier install.
Old 04-28-2005, 07:48 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
EZ-wire. Cheap, and comes with GM style plugs.
Old 04-28-2005, 12:06 PM
JohnM69SS's Avatar
JohnM69SS JohnM69SS is offline
I used Factory Fit wiring kits for my car, which I purchaed through Ricks First Gen (www.rickscamaros.com). When I put the new wiring next to the old wiring, they looked correct and the fittings were the same as the original GM factory fittings. Then again, I was looking for a correct replacement and you might not need that.
I was very pleased.
Old 05-03-2005, 07:47 AM
conekiller13's Avatar
conekiller13 conekiller13 is offline
I used Painless 18 circuit kit last time I put the car together. The hardest part was pulling out the factory wiring. This time I'm going with Painless 12 circuit mini fuse kit.
Dan
Old 06-03-2005, 01:23 PM
i have installed several ron francis kits... with mixed feelings. i have never ever had any kind of problem with them.... but i do not like the fact that all the terminals are "crimp-it-forget-it" where they tie into the main panel. the part in the directions where they tell you to stack terminals on top of each other is also kind of a joke. like i said... no problems.... but i just dont think its the best way to do it. on my newest project i am going to run an EZ wire kit...for the simple fact the panel is prewired. have never run a painless kit... so i cant honestly say anything about it.
Old 06-03-2005, 04:42 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Lots of good luck with Painless wires here.....
