Old 05-02-2007, 08:00 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default 12 Bolt, Narrow or not? Pics please.
OK I'm thinking pretty hard about the mini tubs but the cost of everything is killing me. How would it look if I did'nt narrow the factory 12 bolt? any pics?
69 Camaro, Rag Top
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 05-03-2007, 07:42 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
This is the only one I know of.
http://img8.imageshack.us/my.php?image=scan00042dy.jpg
http://img8.imageshack.us/my.php?image=scan00056dx.jpg
It was in May 2005 issue of PHR. "The Color of Money" Paul McKee's .
Old 05-03-2007, 07:49 AM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
I saw this car at the 2006 Goodguys show in Scottsdale. It is one bad ride. That thing has got a Katech powered LS7 in it, with monster power.
Old 07-14-2007, 09:48 AM
jwillia2's Avatar
jwillia2 jwillia2 is offline
iam running a 12 bolt because i refused to put any ford engineering under my camaro. i think with the mini tub kit wheels tires new gas tank and everything i spent around seven thousand. i think my rearend was around 53 inches .
Ironworks Built 1969 Camaro AKA "HillbillyDLX"
Full DSE suspension LSA T56
Forgeline MonoBlock GA1R OPEN LUG
https://lateral-g.net/members/williams69/
Old 07-14-2007, 12:13 PM
ArisESQ ArisESQ is offline
i'm doing mini tubs without narrowing my rear end. you can still get a decent amount of lip on the wheels if you do the correct backspacing/offset, but not close to what you could have if you narrow the rear.
Old 07-16-2007, 06:33 PM
Todds69's Avatar
Todds69 Todds69 is offline
So you say this Camaro is running the stock length axle? Do you happen to know the wheel backspacing.
Old 07-16-2007, 09:27 PM
Boulder69 Boulder69 is offline
No 12-bolt. That car has a C4 rear. They were snapping half-shafts like mad after the LS7 swap.
I have the PHR with the feature still. One of my favorite cars for sure.
Eric
69 Camaro - LT1 w/ 700R4, DSE springs, swaybar and Konis. Still rockin' it old school with 15" wheels with 60 series tires.
Old 07-17-2007, 12:34 AM
Flash68's Avatar
Flash68 Flash68 is offline
you mind sharing what offset and backspacing you are gonna run? what is the length of your rear end - 55 inches?
thanks
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-17-2007, 05:32 AM
68protouring454's Avatar
Default rims
i am running stock width axle with 18x11.5 in rear with 7-3/4 bs but i would go 8 then use a spacer if needed, my wheels can be milled for more bs if needed
