Old 05-06-2007, 01:33 PM
JamesJ JamesJ is offline
Default 335X30R18 on 18X11 pics please
I am looking for some pictures of some 335X30R18 mounted on 18X11 wheels, all the ones that i can seem to find are mounted on 18X12. Any links would be great as well...
James J.
Old 05-06-2007, 06:32 PM
vipercuda vipercuda is offline
I do not think they will fit. Getting them 12 inch wheels is a chore...
Mike
Time Machines
Old 05-06-2007, 06:51 PM
awr68's Avatar
awr68 awr68 is offline
Jakes are 11.5" w/ a 335 tire, here's a link to a thread with some pics...scroll threw for a few pics. https://lateral-g.net/forums/show...ighlight=Jakes
BTW, I had some 315's on 10" wheels...it worked but I think it looked too old skool as the tire was clearly wider than the wheel...I think you are going to have the same look with the 335 on an 11" wheel.
Tony
'68 Camaro
Old 05-06-2007, 07:10 PM
Thaks for the link
Thats kinda the look that I am wanting, I just am not a fan of the tire flat with the wheel, I like a small buldge.
James J.
Old 05-06-2007, 07:17 PM
Your not going to have a flat wheel with 12s, the section on the 335 is 13 1/2, so you have a good 3/4 buldge which is the way I like it. When you go to 13s, the rim is basically as wide as the tire. Anything less then 12s will actually pull the corners of the tread up and create a high spot in the center of the tire.
Frank Serafine
