Old 05-14-2007, 07:11 PM
Supercharged 86 Supercharged 86 is offline
Default 600++ Hp 454 Bbc
600++ HP 454 BBC
This is a complete 454 motor that is ready for you to reassemble. Add a carb, wires, bearings and few gaskets and you're set to go 10s or better on pump gas.
It consists of the following:
-Gen VI 4 bolt main big block (standard bore)
-LS-6 pistons and pins
-Professionally resized 502 rods with ARP bolts
-Total Seal rings
-Isky roller cam ([email protected], 107lsa, 745-714 lift)
-Isky Red Zone lifters
-1.7 full roller rockers
-4" stroke crank
-World Merlin oval ports with a $1000 in a port and valve job (flow 335/250, 110cc chambers, 2.25/1.90 stainless steel valves, 7/16" studs and guide plates, Isky tool room springs and titanium retainers)
-Dart oval port single plane intake cnc ported for a 4150 carb
-Oil pan and new pump/pick up
Much more I probably forgot
I have a lot of pictures on my photobucket (don't want to kill your 56k with pics here!). Follow the link below...
---> ---> ---> http://s44.photobucket.com/albums/f11/SS86/454/
This is listed for a friend. If you have any questions you're best calling Jo, the owner, at 609-240-8546. Located in NJ. $3250 OBO! Thanks!
John
[email protected]
856 905 1908
Old 05-17-2007, 12:53 PM
Anybody want to take advantage of this killer deal before Sunday?
Old 05-18-2007, 12:41 PM
$2500 this weekend only!
Old 05-24-2007, 04:31 PM
Last buyer backed out. Still available!!
Old 06-03-2007, 01:38 AM
Flash68's Avatar
Flash68 Flash68 is offline
Still available?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 06-08-2007, 09:48 PM
PRO-T PEREZ's Avatar
PRO-T PEREZ PRO-T PEREZ is offline
What Year Is The Block??
Are The Heads Steel, Or Aluminum ???
Old 07-15-2007, 04:22 PM
It was sold a while back.
