Old 05-14-2007, 08:28 PM
saakers saakers is offline
Default External Fuel Pump
I could use your guys help in selecting an external electric fuel pump. I am building a 57 Chevy 2 dr hardtop with a fuel injected 496 BBC. I plan on using a mild streetable cam so I estimate the engine to put out around 600 - 650 HP. I am looking for a fuel pump to handle this HP but not be so load that I can hear it over the engine. Do you guys think the Aeromotive 11106 would be a good choice? Would a pump controller be needed? Thanks for the help.
Old 05-14-2007, 08:58 PM
64duece 64duece is offline
A cheaper and quiet alternative is Holley's 12-920 aka Walbro inline EFI pump. They retail in the $160 range and will support that power without issue. The 26-160 or 26-180 are AN fittings available in #6 and #8 for the inlet/outlet (I prefer the #8)
It's also the same pump supplied w/ Holley's Multiport EFI systems.
Dennis
Moore Racecraft
