Old 05-15-2007, 03:17 PM
jason@gmachine jason@gmachine is offline
Default 4130 TIG welded Custom Roll-bar
here is a roll bar we just finished, its for the owner of Stangwerks.
Full 4130 construction, TIG welded.
Jason
Old 05-15-2007, 03:18 PM
Jason
Old 05-16-2007, 09:49 AM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
Nice looking work man.......!
Old 05-16-2007, 10:00 AM
907rs's Avatar
907rs 907rs is offline
Very nice work! Did you guys pre-heat all of the joints?
Bill
Old 05-16-2007, 02:16 PM
some yes, i used the same method i use to weld up off-road chassis and suspension. Mild filler rod (because its not getting heat treated) and a weave pattern. I just love to weld 4130 over 1020 anyday.
Jason
Old 05-16-2007, 02:50 PM
here is the shots of the romovable harness bar. It is made using special machined units that interlock and bolt together for the ultimate in strength.
Jason
Old 05-22-2007, 04:36 PM
Default 4130 sub-frame connectors
here are some custom Sub-frame connectors i just made from 1.5" 4130 tubing and welded it into the chassis with .120 4130 plate.
Jason
Old 05-25-2007, 09:27 AM
buickfunnycar.com's Avatar
Nice work...love the sfc's!
www.buickfunnycar.com
