Old 05-16-2007, 08:50 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Trunk Pan Replacement
I need to replace the "drop down" section of my trunk pan in my '68 Camaro. Question is...do I need to remove the rear end and place the back of the car on jackstands? I would think you need to take as much weight off the back to eliminate as much felxing as possilbe when the old pan section is removed. Any suggestions?
Chris
Old 05-16-2007, 09:11 AM
68protouring454's Avatar
just cut it out and replace it, no worrys, unless your frame rails are rotted also.
