Old 05-18-2007, 07:52 PM
surreyboy
Guest
Posts: n/a
Default hydraulic clutch question
I have a tko 600 with mcleod hydraulic throwout bearing and a twin disc mcleod clutch. The pedal is very stiff.i have an ATS master cylinder bracket so i guess i really cant change the location of the master on the clutch pedal to increase leverage.Does anyone know if say a spec stage 3 clutch would be alot softer pedal feel?Its so bad i almost want to go automatic.Or could i have a linkage made to change where on the pedal the master is being depressed?
Old 05-18-2007, 08:55 PM
JimM JimM is offline
Even a small change at the pedal will have a big effect on effort. Can you make another hole an inch higher than the one you use now?
Webmaster (lol)
68 Camaro Vert, SS clone, #'s matching 383-TKO500
04 Silverado SS, 93 Polo Green Vette
My Camaro Board
http://www.Jimragtop.com
Jim's Blog!
Old 08-17-2007, 02:26 AM
Travis Rankin Travis Rankin is offline
get it figured???
I had to make z shaped linkage bar for one car.. kinda hack,
but made it work more bedder
