Old 05-21-2007, 10:12 PM
Default DSE project car mirrors? Where to get ?
I was looking DSEs project pics-wich i have found wery inspiring btw!! - and noticed these mirrors on Stavolas camaro.
Can someone identify what mirrors are these? 2 gen camaro or chevelle etc ?
63 Z06
Old 05-22-2007, 01:16 PM
BThibodeaux BThibodeaux is offline
Correct. 2nd gen camaros, and some other GM cars of the same era. I have a new set if you are interested. I have decided to go with another look. The driver's side is remotely operated (manual), and the passenger side is not remote.
Brian T.
2011 Chevrolet Camaro Convertible
Old 05-23-2007, 12:20 AM
Thanks Brian!
You have PM
63 Z06
Old 05-23-2007, 07:23 PM
awr68's Avatar
awr68 awr68 is offline
Those appear to be the Chevelle mirrors '74-? I'm using '77 Chevelle mirrors. The Camaro mirrors are shorter and mount differently. I started with second gen camaro mirrors but didn't like the way they mounted so I got the Chevelle mirrors...
Tony
'68 Camaro
Old 05-24-2007, 06:12 AM
Thanks for the info!! Is the difference between chevelle mirrors and 2 gen at the mounting pad? 2 gen mirrors needs "mounting bracket" and Chevelle mirros mount via 2 bolts ?
63 Z06
Old 05-29-2007, 09:35 PM
awr68's Avatar
Yes, that is the biggest differance. The Camaro mirrors base is a little shorter and to me the mirror body looks to be sized differently as well.
Tony
'68 Camaro
Old 06-08-2007, 01:45 PM
slyck68 slyck68 is offline
Will these mirrors mount directly into the first gen camaro without any modifications or is some fab work required?
Old 06-09-2007, 12:39 PM
awr68's Avatar
reshaping (grinding) the base to the camaro door has to be done in order for them to mount correctly. It's a little tricky but mostly just takes time. I think they mount better on the '69 over the '67-8 door as the profile is a little different.
Tony
'68 Camaro
Old 06-09-2007, 01:54 PM
mark smith mark smith is offline
I just put those same mirrors on my car got mine from a mid 80s cutlass
Old 07-11-2007, 12:50 AM
Hello! I just got a pair from ebay.Looks good so far but i liked to take the mirros off to prep em good for paint. How is it done ? Are replacement mirror glasses available ?
63 Z06
