Old 05-25-2007, 03:14 PM
1970cuda 1970cuda is offline
Default LSX Heads
Who is making 6 Bolt Heads for the GMPP LSX block. GM says it will be late this year or early next before theirs are availible.
Old 05-25-2007, 03:44 PM
camcojb camcojb is offline
http://www.araoengineering.com/LSX.htm
special order option of 6 head bolts. Very expensive, but will likely blow away nearly any LSX head, especially at lower lift areas.
Old 05-25-2007, 05:02 PM
slownova slownova is offline
that is the lasttttt head i would ever concider. not only does it cost a ton, but you will never get it.
it sucks that none of the merlin stuff will work on the lsX block. etp has a 6 bolt head i belive, also dart and W2W will add the 6th bolt your head for a pretty nice number also?
Old 05-25-2007, 05:14 PM
Default ept
do you have a web address for ept?
Old 05-25-2007, 05:31 PM
of course sir. http://www.etheads.com/
alot of lsX blocks at the machine shops but none are done yet. what are you putting it in? whats your goals?
Old 05-25-2007, 06:43 PM
Default lsx
it is going in my wagon the Schwartz is working on. Goal who knows but i might as well get great heads to start with.
Old 05-25-2007, 10:52 PM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
I'm probably gonna be doing a 69 Camaro LS7 twin turbo with those 4 valve AROA heads, the full chassis for it is in process now.
Thanks,
Jeff Schwartz
SchwartzPerformance
Where classic style meets modern technology.
Website : Facebook : Twitter
Old 05-25-2007, 11:05 PM
cool heads, awesome design, just DO NOT give up any cash tell you see the heads or have them in your hands.
Old 05-26-2007, 06:08 PM
Default Schwartz
So many projects so little time.
Old 05-26-2007, 07:53 PM
Stang's Bane Stang's Bane is offline
All pro makes LS7 style heads that will fit that block also.
