Old 05-28-2007, 10:37 PM
Default 3 point seat belts with gage ???
Is there any idea to installa modern 3 point seat belt by mounting the upper left on DSE roll bar ? Could it work ?
63 Z06
Old 06-15-2007, 10:01 PM
Travis Rankin Travis Rankin is offline
Definatly,
I've used one from a newer Jeep TJ a few times... You can get them new fairly cheap from Chrysler. Just weld in a bung for the top mount, and a one for the bottom with a hole above it to locate the mechanism.
Then a pad and bung for the belt catch. Make sure the mechanism is perfectly straight up and down though, our you won't be able to pull the belt out. It locks up at any angle other the vertical.
Metal Shaper
By Trade and Hobby
http://toyotatoday.ca/en/gallery/102
Old 06-19-2007, 09:44 AM
Originally Posted by Travis Rankin
Definatly,
Hello Travis!! Thanks for the reply.Do you any pictures of your installation ?
How about makeing upper seat belt mount adjustable like modern cars do? Maybe machined plate wich have correct slot where belt mount moves up and down could be welded on rollbar ?
63 Z06
