Old 06-05-2007, 11:15 AM
ElcoMan ElcoMan is offline
Default budnik w/ bfgoodrich
im thinking sbout a set of 18 x 9.5" w/ 2255/40zr18 in front and an 20 x 12" w/ 305/50vr20.in the rear.i know ill habe to tub out the wheels wells to make the reay pair fit, but what about the front? Im also going to use a full air ride suspension and might use a schwartz frame so it lays flat on her belly. any thoughts?
Old 06-05-2007, 11:39 AM
novanutcase's Avatar
If Jeff is going to make you a frame you can pretty much dictate the size tire you want to use within reason. I assume that your doing this to an El Camino so I don't think their will be a problem but talk to Jeff and get his input.
John
