Old 06-06-2007, 10:59 AM
Buttz1969 Buttz1969 is offline
Question Front Suspension Options
I am trying to finalize my front suspension plans for my 69 Camaro, and it seems everyday, I change my mind. I am looking for good to excellent performance without breaking the bank.
Currently on the car:
  • BMR Fabrication Tubular UCA
  • BMR Fabrication Tubular LCA
  • Stock Spindles
  • SSBC Disc Brakes
  • QA1 DA Coilovers
  • Stock Steering Box and Linkages
Things I have considered:
  1. Unisteer Power R&P, Upgrade to Wilwood brakes, gmod
  2. Same as 1, but add tall upper and lower ball joints
  3. ATS AFX Spindles, Some C5 brake package, Some steering option
  4. Ditch the BMR CA and replace with GW units, otherwise follow 1
I will say that I am not just out to put a bunch of neat looking parts on the car, it will be driven... hard. At the same time, I want it to show well, and at least semi impress when I show it off. The budget is also a concern, but if there is a considerable handling gain, then I will consider anything.
What are other ideas? Comments?
Thanks all.
Matt Butts
1969 Camaro
LQ4 (In the rebuild process now)
T56
