Old 06-10-2007, 08:55 AM
67ragtp 67ragtp is offline
Default DSE rear shock crossmeber Q for Quad Link
I have my car set up with a mini tub kit and the dse shock crossmember in a 67 camaro. Its welded in straight across. I was wondering if it is in the proper location to convert the car from leaf to quad link? Im not sure if its to far forward now. Anyone done this conversion?
Thanks Rich
Old 06-10-2007, 11:08 AM
68protouring454's Avatar
email dse, but the quadralink crossmember goes in behind axle centerline so that the coil over mounts are in the middle of the crossmember, i think the leaf spring crossmember is mounted at axle centerline.
Old 06-10-2007, 02:31 PM
Datsbad's Avatar
Datsbad Datsbad is offline
It is not in the correct position.
Quad and non staggered crossmembers are not the same .
I forget the measuremnts right now but DSE could help you out .
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 06-10-2007, 05:24 PM
Thanks Guys- I didnt think I would get that lucky. It will probably end up right behind the one Ive installed for the leafs. I will give Kyle a call on monday.
Thanks again Rich
Old 06-10-2007, 07:23 PM
the forward side of the shock crossmember (front of car side) should be 36-1/4 from a 69 tailpanel where the trunk pan flanges up to be welded to tail panel on each side just inside the bumper reinforcements, this meaning the back side of crossmember should be 30-1/4 from tail panel, putting the quadra link shocks in the middle of the crossmember
