Old 06-14-2007, 07:55 AM
sam1 sam1 is offline
Default Fresh 408 SBC With World Heads
408 block with brand new rotating assembly installed - Scat cast crank, KB pistons, purchased as a set from competition products.
World product heads the have been completely gone through, ported, flowed, comp valvetrain, setup for roller cam. $700 in head work, and have the flow numbers.
Asking $2700 OBO for Block/Rotating Assy/Heads - also comes with brand new Edelbrock RPM Air Gap Intake, Holley 725 CFM Street Avenger Carb, full gasket set. Needs a cam kit and ready to go.
Built for street use in a 69 PT camaro that is now gone. PM for pics, will post later, but Imageshack is down right now. In Austin, TX
John
512 748-5677
Old 06-14-2007, 09:38 AM
PICS
Old 06-14-2007, 07:07 PM
Fluid Power's Avatar
location?
Darren
Old 06-14-2007, 08:20 PM
edited, but Austin, TX Thanks...
Old 06-15-2007, 06:39 AM
Head specs: World Products Aluminum
64cc/215cc
Comp Springs: 977-16
Comp Buckets: 4707-16
Comp Retainers: 740-16
Comp Keepers: 611-16
Serviced, Machined, Ported and Flowed, 0 run time since this work.
Flow numbers:
@ .450 224INT/176EXH
@.500 230/180
@.550 226/183
@.600 228/184
Will separate heads/Block/Intake/Carb
Old 06-15-2007, 09:15 AM
JUSTANOVA JUSTANOVA is offline
What Does This Have For Rods?
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 06-15-2007, 11:39 AM
The are 5.7 rods from competition products - ground for stroker clearance. Listed as their part number - 8043335 - Desc: Custom Rods Stage 2
Can be found at competitonproducts.com
Have receipts for Balanced rotating assembly, and head work - $1600 alone.
Thanks,
John
Old 06-19-2007, 01:11 PM
Bump - need cash
$2250 for everything...
Old 06-20-2007, 08:14 PM
Sold!!!!
