Old 06-15-2007, 01:09 PM
GSXTRA GSXTRA is offline
Default Sandable Foam
Does Anyone Know Where To Buy The Sandable Foam Blocks Used To Fabricate With...cant Find It Anywhere...thanks Andrew
Old 06-15-2007, 10:02 PM
Travis Rankin Travis Rankin is offline
You can get the green ones from flower shops
Metal Shaper
By Trade and Hobby
http://toyotatoday.ca/en/gallery/102
Old 06-16-2007, 05:18 AM
Rubes Rubes is offline
http://www.craftsetc.com/store/searc...tyrofoam+block
Old 06-16-2007, 05:22 AM
Thanks Guys
Old 06-16-2007, 07:10 AM
hybrid-t hybrid-t is offline
Depending on what your plans are to finish it, don't use styrofoam. Styrene in a component in most fiberglass supplies and fiberglass resin will "eat" whatever you've shaped. That is if you plan on fiberglassing whatever you've molded. It costs a little more, but the best material to use would be "wonder foam". It's more like surfboard foam and will not disssolve if you lay fiberglass over it. If the link doesn't work you can find it at selectproducts.com. Search for "wonder foam".
HTH
Adam
Old 06-18-2007, 08:50 AM
Thanks For The Help...i Called And Ordered The Foam This Morning...ilpost Some Picks Soon
