Old 06-16-2007, 11:28 AM
nitrorocket's Avatar
Default 0-60 mph on 17"+ plus wheels??
What are you guys getting for 0-60 times on 17" or larger wheels/tires?? I am embarressed to even say my time. I need a time to shoot for a goal??
I need a twin disc clutch. That's all I have to say.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 06-16-2007, 01:13 PM
deuce_454's Avatar
short sidewalls do not do anything for traction.. but with that said a drag radial 275/40-17 or simmillar should be possible to get some good times on, but unless your rear brakes dictate big.. you could drop down to 15 inch rear rims on the strip to get bigger contact patch..
i am also certain that suspension tuning, and practice could get in you in the high to mid 4 second rage in that car on what you are running, provided your tires grip...
Jake: Hit it.
Old 06-16-2007, 03:52 PM
I was hoping more in the 3 something second range. Anyone have numbers on there cars?? All I have to compare to is...nothing.
6 speed
Old 06-16-2007, 05:51 PM
deuce_454's Avatar
a 3 somthing time is getting down there in 60 foot times.. but chevelles dont make bad drag cars, i doubt you will get there on michelin road race slicks, and definately not on cold ones...
i do think that if you are able to get that straight line performance it will at the expense of some cornering and over all handling performance.. you will need more weight transfer, meaning drag race shocks, and relocated trailing arms, and the more aggressive you set up the rear the more prone to wheel-hop it will be at breaking.. you will also need to disconnect the front antisway bar to get some more travel and a myriad of drag specific mods, and lastly. running a clutch you need to get the launch just right..
al of this is allong with soft drag race tires can get your 0-60 where you want and lower, but it wont be able to keep up with an EVO or STI in the corners..
Jake: Hit it.
Old 06-16-2007, 07:26 PM
In the next few days I will try to launch again. With no burnout, and jsut dunping the clutch a 4k, I got a 4.5 second 0-60. I need to find the sweet spot, it was almost a smoke show I had to pull second about 10 feet out to move. Dang stick shifts.
6 speed
Old 06-17-2007, 12:13 AM
projectile's Avatar
projectile projectile is offline
I have a 68 twin turbo camaro with a Mcleod twin disc clutch. It has 18" wheels with 295/35-18 Michelin pilot sport tires.My 0-60 times are in the low 4 second range if I slip the clutch through first gear( like a high stall converter) with no wheelspin.I would like to try other tires but I drive 40 miles a day.80-140 times are more impressive!
Ray
Old 06-17-2007, 07:40 AM
That s pretty good on 18's! I am hoping with a little more practice and some tune adjustments I can get in the 3 second range.
How do you like the twin disc?? A single disc clutch is tricky on the street.
6 speed
Old 06-17-2007, 09:05 AM
Your going to need traction control or switch to an auto. Here is the best traction control unit period. I bet with about an hour of tuning you'll be pretty close to your goal. http://www.racelogic.co.uk/?show=Traction_Control
That would be on a Michelin Pilot or BFG KD type tire.
Jeff Allen
J2 Speed and Custom
Old 06-17-2007, 10:37 AM
californiacuda californiacuda is offline
I have a race logic system, and a very smart gentleman in northern california is trying to modify my system to control 16 fuel injectors instead of the standard 8.
Old 06-17-2007, 10:46 AM
camcojb camcojb is offline
who would that be?
