Old 06-19-2007, 04:29 AM
Birdman's Avatar
Birdman Birdman is offline
Default I swear I just can't get ahead on my 79 TA
I finally got everything I need to get the front suspension back together. I had redone it all - B-body 12" spindles, 1LE rotors, powdercoated a-arms and spindle, poly bushings, diesel S-10 springs, etc. Well, the car never sat right, always too high. So I ordered some Hotchkis springs and Speedway tubular a-arms with the Moog ball joints they sell with them.
So last night I go to get it all together and the damn ball joints don't work. The bolt shaft won't fit all the way through the bolt hole in the spindle. WTF, there is only like 1/8" showing!
The old ball joints on the stock a-arm worked fine with the stock spindle and the b-body spindle, so if these are 2nd gen ball joints, then they should fit.
I am pissed, every time I try and get this thing together something else pops up. I'm almost ready to sell it and start over.
1998 Trans Am - BMR drop springs, BMR LCA relos, Bilstein shocks, Sportmax 18x9.5 wheels, lots of goodies, 6-spd swap, lQ9 swap
1968 Camaro (Patriot Dream project) - Iron LS1, T56, lowered and nitroused PT machine
PatriotDream.org - Help make a soldier's dream come true
Old 06-19-2007, 05:25 AM
s10kool's Avatar
s10kool s10kool is offline
hey i know what you mean
but just get a tapered bit and drill it to fit and your done i used to do it all the time putting s10 spindles on 50's to 70's model cars works great
Old 06-19-2007, 05:33 AM
Birdman's Avatar
I had the drill in hand all ready to do that, but then I thought about something. These ball joints are supposed to fit, so what happens when I replace them at some point and the new ones are correct and then I have wallowed out holes.
I'm gonna call today and verify before I do anything, then comes to drill.
