Old 09-19-2010, 11:18 AM
wrighton wrighton is offline
Default Mini Tub Rear Seat Narrowing
I am curious if any body can put up some pictures of Rear Seats or the process with measurements to narrow a stock 68 camaro rear seat to fit the mini tubs. Thank you for any imput.
Old 10-12-2010, 12:55 AM
redz redz is offline
Get some round bars at the hardware store. It cost me $12. Starting with the seat back, you need to add one vertical bar and 3 "S" shaped horizontal bars on each side and then cut off the old bars to make room for the larger wheel well. Place the vertical bar in the depression of the existing springs. Make sure you put wet towels down before you weld. The old padding burns very easily. The seat bottom is more of a challenge. There is one wire that needs 3 clips undone. The wire needs to be bent with vise grips and then re attach the 3 clips in the new position. I found my welding pliers worked the best on opening these clips. Cut the two wiggly springs after you have re attached the wire. Add 2 bars and then cut off the corner of the frame.
BTC
The Following 4 Users Say Thank You to redz For This Useful Post:
572Camaro (01-24-2021), 68454RS (01-25-2021), Rodknock (03-25-2020), WILWAXU (04-27-2020)
Old 10-16-2010, 11:07 PM
Richio1's Avatar
Richio1 Richio1 is offline
Talking
This is awesome... thank you for posting the detailed pics. I needed this info too so this is perfect. I will be doing mine in a month or two.
Thanks!
Old 11-26-2010, 04:14 PM
JB69ER JB69ER is offline
Great Pictures And Info.
Now If I Can Make Mine Folding Also, All Will Be Good!!! THEY DID THIS ON MUSCLE CARS SEVERAL YEARS AGO..
ALSO THAT ROD LOOKS LIKE "PENCIL ROD" = SMALL 1/4 - 5/16 NON-DEFORMED RE-BAR USED WITH BRICKWORK,
AVAILABLE AT A MASONRY SUPPLY YARD.
Old 11-27-2010, 01:02 AM
holschen's Avatar
holschen holschen is offline
thanks this is great info
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 11-27-2010, 11:22 PM
I used 8' of 1/4" rod and 4' of 5/16" rod. Costs about $12 at the hardware store.
Old 12-04-2010, 03:32 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I printed out all your pics & modded my rear seat today. Its all done except for the welding. (i dont weld nor own a welder) Your pics were spot on & the seat fit perfect around the tubs. You saved me a ton of time. Thanks again.
Old 12-23-2010, 03:18 PM
KHShapiro KHShapiro is offline
thanks for this
Old 05-09-2011, 01:42 PM
AaliyaRocks AaliyaRocks is offline
Can anyone tell me if this applies to a 69 rear seat as well, or would there be a difference in dimension?
Old 05-09-2011, 01:44 PM
Z06vette's Avatar
I have a 69, it worked perfect for me. Should all be the same, except maybe convertible.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
