Old 07-31-2007, 11:26 AM
Default One more time..Dry sump tank for LS7
Yes i am sorry ,i know this has been here many times but i still need to ask this.. If i get the petersen tanks from ATS what needs to done to the right fender ? Scott did you had this exact same system?
63 Z06
Old 07-31-2007, 12:40 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Nothing needs to be done to the fender, but you'll need to cut the inner fenderwell for the tank to pass through, notch the core support where the nuts are and weld them on to the front side and drill new holes in the fenderwell for the 2 bolts. Keep in mind that you need clearance for the tire at full lock, room for the bumper bracket, and still be able to get the cap off the tank. It's not hard, but very tedious and time consuming.
A body saw is a must for cutting the hole in the inner fenderwell.
My LS7 69 Camaro
Old 07-31-2007, 01:47 PM
slenning's Avatar
slenning slenning is offline
I did the same tank setup on my 69. Although first I thought about using a paint can I had laying around instead of buying an expensive tank.
Just Kidding!! Although it was the perfect diameter to lay in there to decide where to cut the hole
Actually I used the 6qt tank from Peterson. I got mine before Tyler started selling the 8 qt. I may change in the future if it is necessary.
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 07-31-2007, 11:14 PM
Thank you Slenning and Scott!!
I ll give a Tyler an email asap!
Brgs Joni
63 Z06
