Old 10-20-2008, 08:55 PM
ratty 46's Avatar
ratty 46 ratty 46 is offline
Default New Guy from Ga.
I've been lurking & enjoy what I read so .......... I thought I'd jump in the water.
I'm building a non conventional vehicle to this forum (I see lots on camaros, vettes, stangs, cuda/challanger stuff) but my vehicle is a bit different:
1946 Ford long door coupe
It's not that I've not had the camaro, vette & stang vehicle I just wanted something a bit more unique (for me).
I'm in the process right now of installing a Chassis Works (ALSTON) 4 link, coil over, FAB9 rear, tube A-arm, coil over front with R & P steering. Front & rear BIG Wilwoods. I've already unloaded all the suspension parts plus the flathead, 3 speed & torque tube drive line. The skinnie steelies & bias plys have also been ditched.
A simple Trick-flo headed SBC with a carb feed 68mm intercooled turbo is replacing the original 239. Trans is muncie 4 speed now but $$ & a deal will bring home a 5 or 6 speed trans. Wheel choice has been made to American SaltFlat Specials in 16" hoops.
Interior will be sparce with a bomber theme through out. Lots of aluminum & rivets.
Ride height will be in the 4-5" daily driver position with the ability to run a little closer to earth.
I know this is not your "normal" g-machine as it cuts the wind like a brick .... but its my brick!!
I'll post some progress pix if anyone has any interest.
Ratty 46
Old 10-21-2008, 09:40 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Post up some pics.
Sounds like a fun project.
Old 10-21-2008, 11:03 AM
ratty 46's Avatar
It is.....and will be.......
Pix of when I got it home from Ks. back in April:
and right now .......ready for the transformation:
and parts to add on:
Ratty 46
Old 10-21-2008, 03:55 PM
GHOSTDANCER GHOSTDANCER is offline
Kool looking project
Old 10-21-2008, 08:39 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Very cool! Keep posting with progress.
John Paige
lab-14.com
Old 10-22-2008, 05:39 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome. Keep us posted.
My LS7 69 Camaro
Old 10-22-2008, 07:22 AM
ratty 46's Avatar
Thannks guys.
I sold a pro street 66 chevy II & my 62 Ford Uni to fund this build. The 66 is out in Tx now racing & the uni went local & is a daily driver.
I've made more progress in removing some of the original X members - which will be replaced with new tubing.
Here's a shot of the cherry front end.
I'm trying very hard to have this done for the april Fla. Billet Proof get together. We shall see!!
It's a fun project...... so far & should be very unique when finished.
Unlike most of the cars here on this forum with slick paint - mine is actually done paint wise.
Ratty 46
Old 10-24-2008, 03:08 PM
ratty 46's Avatar
After removing & selling off the front & rear suspension, engine, trans & torque tube along with the wheels & tires it was cutting time.
So far I've removed the front & rear suspension X member mounts along with the center part of the X member.
My intention is to install some fab'd C channel to run on each side parallel to the frame back into the remaining X member. I'll be using this as the side mounting point for my front 4 link setup, driveshaft loop, trans mount & possibly an addt'l brace for strenght.
I also scored a Currie built 9" third member with 4:11 gears & a detriot locker.
So...... as soon as I get the "C" channel I'm back in biz & moving forward.
Ratty 46
