Old 11-07-2012, 11:07 AM
broken1234 broken1234 is offline
Default Advantages of LSX block for twin turbo application?
I'm in the planning stage for a twin turbo 8/900 hp 70 Camaro project.
Being new to forced induction, I'm curious about folk's thoughts and suggestions on just how strong I need to build the bottom end for this HP set-up.
It has been suggested that an LSX block with additional head studs, and an appropriate set of heads, would be a worthwhile investment.
Can someone comment on their experience here and suggest some parts combos that will get me where I want to go without overkil or breaking the bank?
Thanks,
Brad
Old 11-07-2012, 02:03 PM
ironworks's Avatar
There is no such thing as a 900hp twin turbo budget engine that will last.
The LSX block is awesome, it is heavy but super strong. GM says it can handle 2500 hp. A billet LS block will do the same for about triple the cost.
As far as that the engine will be expensive to make it last, unless it's a one hit 900hp wonder.
Old 11-07-2012, 02:21 PM
Rybar's Avatar
Rybar Rybar is offline
Brad a good buddy of mine is building a 427 LSX and he's putting twin T76 turbo's on it. This is for a Drag Car but I believe he's going with 6 bolt heads/studs and fully forged internals. Brand names I'm not sure.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-07-2012, 05:42 PM
badmatt's Avatar
badmatt badmatt is offline
A stock studded 6.0L iron block will take that no question.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 11-08-2012, 05:16 AM
Well, the clearer story is this; I want about 700 hp at the rear wheels. I'm told that I'll lose about 15% in the driveline (T56 and a Ford 9"). I will have access to an engine dyno.
It's been suggested that my biggest concern is internal pressures, thus the LSX block and it's extra head stud. Obviously all forged stuff in the bottom end. Is this valid?
What else am I missing here?
I don't expect to regularly run the engine at high boost levels. This car won't be a regular racer or autocrosser, just a street car that occasionally hits the track...
Old 11-08-2012, 08:12 AM
camcojb camcojb is online now
I've seen many 700 rwhp+ LS engines with the stock aluminum or iron blocks. The LSX block is a great platform, but not required. Where it comes into play is if you'll be running high boost, like 20 psi+. If it takes that much boost with your combo to make 700 rwhp, change your combo............
Easy to make big power with a forced induction LS engine. The TT 402 in my last car made well over that with a 4L80E and 9", and the boost level was at 14 psi. At that boost level you do not need the extra head bolts. Never got a full pull due to it shutting the dyno down around 4800 rpm due to excessive torque, but I'm confident in saying it was over 700 rwhp.
Old 11-08-2012, 09:16 AM
Thanks for the reply... might I ask what turbos you were running and what sort of heads and bottom end pieces you had in your 402?
Old 11-08-2012, 10:52 AM
71RS/SS396's Avatar
This guy is the "man" for boosted LS engines http://www.kurturbanperformance.com/
Old 11-08-2012, 10:57 AM
Thats where I got my engine parts.
He has an offset piston for the ls that quiets the strokers a lot.!!!!
Old 11-15-2012, 05:49 PM
gnx7's Avatar
gnx7 gnx7 is offline
If you need a NorCal machine shop I have S&S Automotive in San Leandro, CA build all my motors. Ex-NHRA guys. They did my Buick GN turbo V6 stuff back in the day and now LS motors. They ship worldwide and know their sh*t.
In a nutshell the LSx block is overkill... plus is a fat pig. An LS alum block is around 80lbs. An iron block is another 80lbs or so heavier (160lbs total approx). The LSx block is yet again another 40-50lbs heavier than the production iron block.
If you want 700rwhp you can get a 2005+ engine that has LS2 rods, upgrade the cam/springs/pushrods, LS9 head gaskets, ARP studs, turbocharge it, install bigger injectors, upgrade the fuel system, tune it and you are good to go. No need to build an LS motor with only 700rwhp. The limit of 4 bolt style production heads is around 1000rwhp safely. You can certainly make more.. but the head gaskets will eventually let go. Thicker deck aftermarket heads help at the big HP levels for head sealing. There are a number of cars with forged bottom ends and stock LS3 heads/intake making 1000rwhp+.
If it does pop.... then build it. With the proper tune and quality fuel you shouldn't have issues. For extra measure you could open up the ring gap on the pistons and install rod bolts.
I'm building my car with an '08 alum 5.3 (stock shortblock) with ported 5.3 heads (not needed), LS9 head gaskets, ARP head studs, LS6 intake (not needed), small 225/223 cam, ported throttlebody (not needed), with a medium size TC78 turbo and shooting for 750-800rwhp on e85.
Most of the time I'll putt around with 550-600rwhp and turn it up when needed
If you have the extra money run an LS2 or 6.0 iron block, stock LS crankshaft, some good forged rods (CompStar), and JE/Wiseco/Diamond forged pistons. That will handle 1000rwhp+ with a good tune.
My buddy has a forged LS3 with ported LS3 heads/intake running a GTS76 turbo on e85 and makes 620rwhp on 3.8psi. 750rwhp on 6psi...960rwhp on 14psi. No issues with his setup and he runs a stock LS3 block/crankshaft.
Here is my engine bay awaiting turbo fab.
