Old 07-22-2017, 09:36 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Default Aftermarket C6 Front Suspension components
Item Location (City/State):
Covina, CA
Price:
$40 - $650
Description:
I am selling off most of my C6 front suspension stuff, going a different route because of the issues I have found with my frame. This would make a great setup if someone is buying a bare c6 front frame and need the components for it.
The GMR C6 front hubs. Includes brake rotor adapters, 8 on 7", for The Brake Man (TBM Brakes) 13" rotors or others and includes the socket to replace and repack the bearings. They have 1/2" studs set up on a 5 on 4.75" bolt pattern. Rotor adapters are still available for Wilwood and Baer brakes. $650 obo.
20170722_173233 by Jonathan Feltis, on Flickr
C6 Corvette uprights, new just mocked up on car. The steering arms have been cut off. SOLD
20170722_174309 by Jonathan Feltis, on Flickr
AGR performance power steering rack. Part#712581, Never used, just mocked up. Slight surface rust on some of the hardlines as seen in the pictures. includes tie rod ends. SOLD
20170722_180526 by Jonathan Feltis, on Flickr
Speedway Engineering 3 piece sway bar 1-1/4" x 32", with steel arms, bushings and hardware. SOLD
20170722_183644 by Jonathan Feltis, on Flickr
Chassis Works shock mounts. $45 obo.
20170722_192450 by Jonathan Feltis, on Flickr
Aurora rod ends, 3/4" x 3/4". There are 5 AM12T right hand and 5 AB12T left hand. Teflon lined. $40 Ea obo
20170722_184538 by Jonathan Feltis, on Flickr
ARP wheel studs, Part #ARP-100-7705, 2 packs of 5. $10 Ea.
20170722_181857 by Jonathan Feltis, on Flickr
Thanks,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 07-26-2017, 07:01 PM
Jtomas801's Avatar
The C6 arms have been sold.
Thanks,
Jon
Jonathan Feltis
Old 08-01-2017, 08:17 PM
Jtomas801's Avatar
Lowered prices, open to offers.
Thanks,
Jon
Jonathan Feltis
Old 08-01-2017, 11:31 PM
232_ray 232_ray is offline
GMR hubs? Any chance u got a link for those things. I'd like to do I little research on them. Thanks.
Old 08-02-2017, 12:07 AM
Jtomas801's Avatar
Hi there,
From the looks of it they are no longer making these, but here is some links with information on them:
https://youtu.be/LfIOdK2vhlY
https://lateral-g.net/forums/showthread.php4?t=40990
They are really nice pieces and are rebuildable with standard size bearings, Inner bearing: LM300849, Outer bearing: L44649, Both "Timken".
Also included a trick socket to remove the bearings. If the brakeman rotor adapters don't work for you, there are adapters for Wilwood and Baer available from the person I purchased these hubs from.
Let me know if you have any other questions.
Thanks,
Jon
Jonathan Feltis
Old 08-14-2017, 07:45 PM
Jtomas801's Avatar
Bump, adjusted prices.
Thanks,
Jon
Jonathan Feltis
Old 09-08-2017, 09:18 PM
Jtomas801's Avatar
Back to the top.
Thanks for looking,
Jon
Jonathan Feltis
Old 12-04-2017, 05:18 PM
Jtomas801's Avatar
Lowered prices.
Thanks,
Jon
Jonathan Feltis
Old 12-09-2017, 10:49 AM
aany001's Avatar
aany001 aany001 is offline
Jon can the rotor flanges be removed to run a factory C6 rotor?
Old 12-09-2017, 07:25 PM
Jtomas801's Avatar
Yes the rotor adapter can be removed and/or be replaced with another adapter for other rotor bolt patterns. I believe it can be but, it would not be simple. It would add track width to each side, the wheel studs would be short and you would need to shim the caliper to match the rotor. I will pm you a link with some info on it. It would probably be cheaper/easier if you went to a two piece rotor with the correct rotor adapter.
Thanks,
Jon
Jonathan Feltis
