Old 03-25-2010, 12:26 PM
fletcherscustoms fletcherscustoms is offline
Default Show me your A1000 mounting!!
Guys I'm waiting on my Sumped Rick's Stainless tank to get here for my 70 camaro we are doing. Anyone got any pics of details on where they mount or recommend mounting the Aeromotive A1000. Does the A1000 have to be below the fuel level, or will it pull fuel also?
Chad Fletcher
Fletcher's Customs and Speed
229-221-4690
[email protected]
Old 03-25-2010, 01:26 PM
Chad ==
They WILL pull vacuum - but fuel boils at vacuum -- the opposite of a radiator!
Mount it so it has a 'flooded head'.
Old 03-25-2010, 01:28 PM
That was my understanding also. Jut having a hard time trying to figure out where to mount this thing and the filters. Not a whole lot of real estate back there with the tank and watts link
Chad Fletcher
229-221-4690
[email protected]
Old 03-25-2010, 01:52 PM
I'm pretty sure you can mount that pump in the tank if thats possible. It keeps it cooler and less noise to.
Old 08-02-2010, 05:12 PM
MotleyDrew MotleyDrew is offline
Here are Install Instructions
http://aeromotiveinc.com/wp-content/...9/12/11101.pdf
Old 08-02-2010, 07:58 PM
BBC69Camaro's Avatar
Not a A1000 but their SS Pump with a Rick's sumped tank:
Mounted on a straight bracket bent at like 45* angle with bolts through grommits (to dampen pump vibration) mounted to a some aluminium channel that was made into a "T":
All tucked up in between the pumpkin and tank:
The Brackets being powder coated silver:
Also each of side the pump has a short stainless steel flex hose to allow for motion/movement.
Routing of fuel lines:
Even put a fuel cooler right before the carb on the passenger's undercarriage:
