Old 08-10-2010, 08:39 PM
speedshftr speedshftr is offline
Default will these lowereing blocks work with my setup
i have a 68 camaro with a mono leaf rear.it needs about 3 inches lowered in the rear.the car is a slow cruiser and not a high hp car.i need inexpensive fix to get the rear down.will thse work for my setup.im running 18 inch rushforths also.
http://cgi.ebay.com/ebaymotors/67-68...-/300314913046
Old 08-12-2010, 01:57 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I would think so.
Old 08-12-2010, 03:13 PM
deuce_454's Avatar
lowering blocks cause spring wrap... uou need to install some sort of under or overrider tractionbars if you expect it to behave nicely with tall lowering blocks and full throttle/braking..
but yes they will work
Jake: Hit it.
Old 08-13-2010, 05:48 AM
redfire69's Avatar
I posted this over a p/t, your car is turning out so nice, I would spend the extra cash and go w DSE 3 inch lowering springs and a multi-leaf conversion. Good luck-
Ron
69 Camaro Redfire
Old 08-13-2010, 08:38 AM
TA219's Avatar
TA219 TA219 is offline
I put some blocks under my car because even with Hotchkis lowering springs the rear was up pretty high (until the leaf springs settle in) but I found some at my local autozone that were much cheaper
67 Camaro
10 Camaro
