Old 08-16-2010, 09:35 PM
aany001's Avatar
aany001 aany001 is offline
Default Can I use a smaller booster
I am running 02 C5 Z06 front brakes and 01 LS1 rear brakes with a C5 master cylinder and a large factory vacuum booster in my 69 camaro.My question is can I run a smaller booster cause I have an interferance with my coils on my LS1 hitting my larger booster.Thanks in advance
Steve
Old 08-17-2010, 08:55 AM
Musclerodz's Avatar
Steve
you should be able to go to a 9" dual and not lose any braking force.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-17-2010, 08:57 AM
9" or even our 8" dual make more boost then a single 11" from the factory.
Frank Serafine
Old 08-17-2010, 10:09 AM
Apogee Apogee is offline
Frank is correct, a dual-8" diaphragm is more or less equivalent to a single-10.75" booster in terms of gain, albeit slightly more on paper. The dual-9" booster like those used on the C5 Corvettes provides approximately 30% more boost than the single-10.75", so either should be step in the right direction without any real drawbacks to speak of.
Tobin
KORE3
www.kore3.com
Old 08-17-2010, 11:45 AM
Rybar's Avatar
Rybar Rybar is offline
Had the same problem as you and swapped to a CPP 8" Dual Diaphram Booster.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 08-17-2010, 05:11 PM
aany001's Avatar
I already have a factory C5 booster at home..can I use that bad boy??? I wonder what kind of fab work would it take to install it?? Has anyone tried this yet?? Guys thanks for all the input.
Old 08-17-2010, 05:14 PM
aany001's Avatar
Rybar what did that booster cost you??
