Old 03-04-2019, 01:17 PM
DWC's Avatar
DWC DWC is offline
Default DSE subframe connectors- Interior finishing question
I've installed DSE subframe connectors on my 68 Camaro and they protrude into the rear passenger floor pan area. This will prevent the carpet from laying totally flat.
Has anyone come up with a solution to build up the area on either side of the connector so the floor is flat? Maybe use dense foam, balsa, or ???
Or should I just not worry about it, throw in the carpet and go?
Daniel
Old 03-04-2019, 03:23 PM
dhutton dhutton is offline
I use dense foam and jute.
Old 03-04-2019, 07:51 PM
Gmachine1911's Avatar
I used 1" dense foam and built it up in layers to follow the floor contours. Glued the layers together with 3M spray adhesive. A 4" grinder with a flapper disc works perfect for shaping it. Here's what mine looked like when it was done...
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 03-05-2019, 04:52 AM
DWC's Avatar
DWC DWC is offline
Thanks guys. Foam it is.
Thanks for the photo Shane.
Daniel
The Following User Says Thank You to DWC For This Useful Post:
Gmachine1911 (03-05-2019)
Old 03-06-2019, 09:45 AM
ur-n-8 ur-n-8 is offline
Wow that looks really good.
The Following User Says Thank You to ur-n-8 For This Useful Post:
Gmachine1911 (03-17-2019)
Old 03-16-2019, 07:58 AM
paulk68 paulk68 is offline
Looks awesome can you tell me about your shifter setup, shift boot, shift lever and lever size?
thanks
Old 03-16-2019, 05:04 PM
DWC's Avatar
DWC DWC is offline
I wanted to follow up with my solution. I found some anti-fatigue mat from Northern Tool for $10. It was dense enough to accomplish what I wanted. Cheap, simple, effective.
Daniel
dhutton (03-16-2019)
Old 03-17-2019, 07:13 PM
thanks
Thanks! No problem...the shifter boot, trim ring and lever are from Finch. It's the smaller of the two sizes he offers. The shift lever is the 8" and the shifter handle is from American Powertrain. The trim ring is a two-piece design and everything was top notch quality. The shifter handle came with two set of bushings with different offsets so you can get the angle you want. Hope that helps!
Shane
#theanchorholds
Old 03-21-2019, 10:58 AM
jlwdvm jlwdvm is offline
I used Harbor Freight floor mats that I cut to shape: dense, cheap, easy to cut!
