Old 11-12-2007, 12:17 AM
Default Will "wayne due" frame headers work with DSE frame ?
Stainless works have "wayne duy" headers for 1 gen camaro with LSx.
http://www.stainlessworks.net/cart/p...oducts_id=1166
Would these work with LS7 and DSE frame as well ??
63 Z06
Old 11-12-2007, 05:35 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Not sure if they would fit in the frame, but more importantly, those headers aren't the best for an LS7. The LS7 has a different port shape and those headers are 1 3/4". If there's anything about the LS7 that isn't up to par with the rest of the motor, it's exhaust flow. It really needs 1 7/8" primary or a 1 3/4 to 1 7/8 stepped header... and even more so if you do a cam swap.
My LS7 69 Camaro
Old 11-12-2007, 05:53 AM
Thanks again, Scott!
Yes i thought i would ask em to get me a weld on kit with 1 7/8" or even 2" primary pipes. But what could be difference between WD or DSE frames? Both are frontsteers etc. And take wide fronts . Scott you had a WD frame right? Have you ever compared it to DSE ?
63 Z06
Old 11-12-2007, 06:01 AM
XcYZ's Avatar
Will SW do that? Back when I was looking for headers, that wasn't an option from them.
My frame is considerably different.
I went with Kooks 4th Gen F-body LS7 swap headers and then had Stenod Performance move the #1 primary for me.
My LS7 69 Camaro
Old 11-12-2007, 06:02 AM
The Rack and Pinion should fit, and I just happen to have a set of the Rack and pinion headers in stock!
Frank Serafine
Old 11-12-2007, 06:05 AM
Speaking of stock, have you any good news to me
63 Z06
Old 11-15-2007, 07:16 AM
Gr8t68's Avatar
Gr8t68 Gr8t68 is offline
Default WD Sub with LS1 - Headers?
Thanks for the link to Stainless Works. Has anyone had any experience with Hooker's Super Comp Block Hugger Header: SBC LS–1,Tube Size 1.625", Collector Size 2.5", Port Shape: Round, Ceramic coated finish? Do these limit performance? Thanks.
Old 11-15-2007, 11:25 PM
Frank, you going public?
