Old 11-29-2007, 01:53 PM
parsonsj parsonsj is offline
Default Lower price: 1967 Chevy II Nova "II Much" for sale
For Sale: 1967 Chevy II Nova, "II Much". Popular Hot Rodding Cover Car (October 2007). II Much has had significant magazine coverage (exhaust, front suspension, rear suspension, engine, etc.) over the past several years. It sports a sleeved and stroked LS2 (427 cid) that makes 600 hp, a TKO 600 5 sp, and a Moser 9 inch rear. It has a Katz Tsubai custom designed track-proven suspension, Wilwood brakes, a custom race-inspired interior, and flawless paint.
The car is equally happy cruising down the highway and going 160mph on the race track. You can have fun at your local autoX showing the Miata boys that muscle cars can compete, and at the local car show showing the numbers-matching crowd something they haven't seen before.
Technical specs are below.
See more information and photos: PHR Feature Article, V8 TV Interview, at Road Atlanta, and my website.
I want to build another car, and I don't have the space to keep it and build another one.
Please PM me if you are serious about buying the car. I am happy to provide some help delivering the car or meeting you half way.
II Much Tech Sheet
Chassis, Suspension, Steering, Brakes
Frame:
Art Morrison. 2x4x.120 frame rails, 1.75x.083 4130 12 pt cage. Custom floor, firewall, wheel tubs, transmission tunnel, and trunk fabricated from various gauges of 1018 cold rolled steel.
Suspension: (front) Custom designed short-long arm. Katz Tsubai design. Features 4130 tubular lower control arms, needle-bearing upper control arms, Howe Racing ball joints, Stock Car Products modular sway bar, C4 hubs, and custom fabricated aluminum uprights, coilover mounts, and crossmember.
(rear) Custom designed (Katz Tsubai) road racing 3 link. Features adjustable control arms and panhard bar plus custom sway bar.
Designed for 1+G in street settings, 1.15G in track mode, using HAL QA1 coilover shocks and springs all around.
Steering: custom Tony Woodward rack, Lefthander Chassis tie rods, and custom machined 4340 steel steering arms.
Brakes: Front- Wilwood 14” 2pc rotor, slotted/cross drilled, Wilwood 6 piston radial mount caliper, Rear- Wilwood 12” rotor, slotted/ cross drilled, Wilwood 4 piston fixed caliper, Pedal assembly- Wilwood firewall mount dual master cylinder and clutch assembly with balance-bar adjustable front to rear bias. Hydraulics- Wilwood 0.75 master cylinders (x2)
Exhaust: Custom built 1-3/4 304 SS primary tube headers to a 3” exhaust with MagnaFlow X-pipe and bumper outlet. All header materials and bends supplied by Stainless Works. Exhaust system supplied by MagnaFlow.
Fuel system: Custom built 16 gallon baffled aluminum fuel cell with sump in rear trunk area, external Aeromotive A1000 fuel pump, stainless steel hardlines.
Wheels and Tires: Kinesis K18 3pc rims, dark gray anodized. (front) 18x9 (rear) 18x11. Pirelli 265/35/ZR18 and 315/30/ZR18 P Zero Corsa tires.
Engine, Valvetrain, & Underhood
Engine:
Wegner Automotive Research 620 hp 427 using Rapid Motorsports sleeved LS2.
Internal: Lunati 4” crank, Pro-Modified rods, Lunati forged pistons. ARP hardware throughout. Wegner Automotive Research drivetrain and Lunati Voodoo cam.
Intake: GMPP single-plane throttle-body intake
Heads: Wegner Automotive Research CNC ported aluminum heads.
Engine Management: FAST XFI controller and Holley throttle body with custom built wiring, using MIL spec connectors
Transmission: TKO-600 5 speed (road race version)
Clutch: LS6, with Howe TOB, Wilwood master, and custom pedal.
Rear End: Morrison 9" housing, Moser Engineering nodular iron 3rd member. TrueTrac differential, 3.25 ratio, 31 spline axles.
Engine Cooling: Ron Davis aluminum radiator with 1-1/2 tubes and dual electric fans.
Hoses: Stainless and aluminum hardline, along with Earl's and Brown & Miller race hose.
Interior & Trunk
Seats:
Sparco Monza race seats in black cloth
Interior Trim: Custom interior in black suede and vinyl. Dynamat insulation/noise/heat dampener.
Shifter: Tremec Billet shifter
Steering Column & Wheel: Ididit tilt column with Borgeson U joints, Sparco 3 spoke racing wheel with pull off hub.
Miscellaneous: Schroth 4 pt belts with cam quick release latches.
Appointments: Vintage Air Gen IV Magnum air conditioning, featuring cold a/c, and full defrost and heat.
Stereo: Integrated iPhone-based stereo. GPS apps work - including Navigon turn-by-turn voice navigation.
Exterior
Body Panels:
Harwood fiberglass cowl induction hood, custom reverse hinges. Custom adjustable front and rear spoilers. Fabricated aluminum trim, stainless mesh, fiberglass bumpers, etc.
Paint: PPG Blue with metallic black and anodized aluminum trim.
Trim & Moldings: custom fabricated and anodized aluminum, custom II Much badge.
John Parsons
Old 11-29-2007, 02:36 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Good luck with the sale, John. I'm glad I got to see it in person last month.
My LS7 69 Camaro
Old 11-29-2007, 04:04 PM
Mizfit's Avatar
Mizfit Mizfit is offline
great car and best of luck, I am sure it will sell fast.
Taylor
Taylor Day
www.mizfitmotorsports.com
[email protected]
Old 11-29-2007, 06:21 PM
Thanks guys. Scott, it was nice chatting with you at SEMA.
jp
John Parsons
Old 11-29-2007, 06:44 PM
awr68's Avatar
awr68 awr68 is offline
I knew this day was coming and I'm with Scott...I'm VERY glad I was able to see II Much in person at SEMA! It's an increadable car and was very fun seeing it built over the years! Good luck John and I hope it goes to someone that will truely enjoy it (use it!).
Tony
'68 Camaro
Old 11-30-2007, 10:43 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I Know the feeling your having John. Same reason I sold the 57 to start the now never ending 55 I'm sure it is a bitter sweet thing about selling it, but sometimes it as much fun building them as driving them. I'm glad I was able to see it in person at SEMA. Workmanship and quality is second to none. Truely a work of art.
Brent
Old 12-05-2007, 05:50 PM
c.schulz's Avatar
c.schulz c.schulz is offline
John, Good luck with the sale. What an honor to have come to michigan last year. The design crowd loved the car.
Chris
71 RS Pro-Touring thing.....will it ever be done?? Not with out a second mortgage! SOLD
Old 12-05-2007, 06:05 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
John I hate to see you sell the car. Who ever buys it is getting a deal and will have a blast for sure.
Curtis
Old 12-09-2007, 07:03 AM
No sale at PRI. I had (have? Not sure the negotiations are dead yet) two decent conversations with potential buyers there.
Next, I'm going to talk with the guys over at Mecum Auctions. They've got a kind of mini-Barrett-Jackson thing here in central Florida in late January. (thanks Jeff!).
Thanks again for all the kind words!
jp
John Parsons
Old 12-09-2007, 08:54 AM
awr68's Avatar
You sound determined to sale and start the next project...good for you!
Tony
'68 Camaro
