Old 04-03-2008, 11:44 AM
monza's Avatar
monza monza is offline
Default Weight Guess?? between these motors...
Turbo Buick 3.8 V6 VS. any LSX less say LS2 for arguments sake (aluminum block)
I have a debate going on somewhere else.... claims a Turbo Buick 3.8 V6 is 'way' lighter I said I doubt it with out any reference or research.
Any know the weight difference?
The debate started over which is better for the back of a Corvair, my vote LSX
thanks
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 04-03-2008, 12:04 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Posted by Steve1968LS2:
457.6 lbs, LS1 auto; 497.2 lbs, LS1/LS6 manual
From Chevy2only; http://www.chevy2only.com/index.php?..._position=54:8
Weights are from carb to oil pan with HEI dist, harmonic balancer, and iron water pump.
SMALL BLOCK
All iron small block 520 lbs.
Alum heads w/iron small block 480 lbs.
All alum motor 389 lbs.
BIG BLOCK
All iron BB 754 lbs.
Alum heads with iron block 660 lbs.
All alum BB 501 lbs.
Old 04-03-2008, 12:14 PM
Efi69Cam Efi69Cam is offline
I read somewhere that the aluminum ls4 in the FWD Impala is the same weight as the all iron 3.8
I think the series 2 and 3 3.8s had shorter decks than the RWD 3.8s so if anything the LS motor is slightly lighter than the 3.8 turbo.
