Old 09-08-2008, 02:09 PM
Default Reminder to get a fire exstinguisher in your car!
It is very possible I would have lost my car today if it wasn't for having a fire exstinguisher handy. Took my car into ATS and on hard decel the engine flooded and wouldn't refire. The unspent fuel caught on fire in the header collector. Thankfully I remembered to bring it along and Tyler also came running with his and we got it out right away. Buy yourself one today and put it in your car! I was very fortunate but things could have turned out much different. Bad luck but also good luck that it's not on the way to the junk yard right now.
Old 09-08-2008, 02:31 PM
Steve1968LS2's Avatar
And for the sake of your car buy a good one. The money you spend on a halon type unit will pay off big time if you ever have to use it.
Glad this ended well for you!
Steven
Old 09-08-2008, 03:01 PM
awr68's Avatar
awr68 awr68 is offline
Damn Todd that was close!! Glad it turned out fine in the end! How bad will the clean up be? When we had a kitchen fire I unloaded a fire exstinguisher and was able to put out the fire....but DAMN was it messy!!
Tony
'68 Camaro
Old 09-08-2008, 03:28 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Yep, I have one in the car. You just never know... and it may not be your car, it could be a friends.
My LS7 69 Camaro
Old 09-08-2008, 03:37 PM
skatinjay27's Avatar
damn that f'in scary!!! good thing you guy caught it quick how was the drive over there though
is he doing the exhaust now? did you decide on dumps or over the axel?
glad no damage was cuased.
AJ
Old 09-08-2008, 03:41 PM
It will be all stainless over the axle. The drive was great! I hadn't calibrated my speedo and my buddy said I was going 90-100 on I 15 South of town. Car drives absoutely awesome. Talked to Frank and he thinks a peice of debris from all my fuel plumbing is playing with my needle and seat. I noticed under hard braking it would try to die on me on other test rides. Never actually died on me though. Going to make sure my float levels are correct and clean out the carb. This wouldn't of happened with exhaust on the car. Just to much pride to trailer it but it almost cost me a bundle. I still can't believe it.
Old 09-08-2008, 03:48 PM
I've never ran so fast in my life. I heard the car coming about a block away and stepped out side to watch the approach. When he went to re-fire the car after the stall flames shot out from the headers and lit the under body right up. I swore that I would burn my arms to try and save the car if need be. I'm glad it only got some yellow powder on it and Todd lost some wiring insulation near his TKO 600 wiring. Other than a new element for his air cleaner, the car came away mostly unharmed. I had visions of us watching the car burn to the ground and I'm super grateful that it didn't. He will be detailing a once flawless engine compartment for months and will probably find fire extinguisher dust for the next 8 years.
Tyler
Old 09-08-2008, 03:55 PM
Tyler, thank you for your quick thinking and helping me put out the flames. I think things could of been much worse without the dueling extinguishers. My good buddy Ben that was following let me know right away as well. That sks undercoating holds up to the heat!!! Glad I didn't paint the floors!
Old 09-08-2008, 03:57 PM
V8TV's Avatar
V8TV V8TV is offline
Glad to hear it wasn't a catastrophe... even though it was a mess! We've got some H3R halon ones at the shop and in our cars. Halon makes no mess, but not cheap. I guess cheaper than the hours spent cleaning up the powder kind. Halon is no longer made thanks to EPA regs, so these are all reclaimed units, causing the price crazyness. Interesting FAQ about the stuff:
http://h3rcleanagents.com/support_faq_2.htm#q1
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 09-08-2008, 03:38 PM
Nothing a few hours of elbow grease won't fix. Have a couple wiring harnesses that the mesh melted on but the wires look fine. What size would you guys recommend? 2.5 pound?
