Old 02-17-2011, 11:12 AM
Default Anybody running a backseat with a Quadralink?
Admittedly I was torn as to whether this should be in interior or suspension section .
Initially I thought the DSE Quadralink would preclude me from having a backseat. Then I happen to notice that DSE says you can still run one. I can't remember seeing anybody with that setup though. The builds here that I'm aware of don't have backseats. Anybody running Quadralink and a backseat? What mods to the seat frame are necessary?
The G-link was at top of my list for this reason. However, I think the Quadralink has the advantage when it comes to routing large exhaust pipes up over the axle.
Thanks,
John
John
'71 Nova (Build thread)
FFR Roadster
Old 02-17-2011, 01:34 PM
slenning's Avatar
slenning slenning is offline
You can definately have a back seat with a Quadralink. I had to narrow the seat frames 3" I believe for the mini tubs and had to notch a little under the seat frame for the upper pockets.
Uploaded with ImageShack.us
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 02-17-2011, 01:55 PM
6spdcamaro 6spdcamaro is offline
I just finished modifying the back seat frame to fit with the Quadra-link and mini tubs. All that is necessary for the Q-link, is a few small wires near the upper four link brackets need to be cut a re-routed. The minitubs are a little more involved. Its not a difficult job to do, just a little tedious.
Ken
Old 02-18-2011, 05:54 AM
Thanks guys. Good to know it is possible. Hopefully the same applies if it is used in a Nova
John
FFR Roadster
Old 02-18-2011, 08:29 AM
BBC69Camaro's Avatar
For narrowing the seat after a mini-tub you might check out:
Mini Tub Rear Seat Narrowing
https://lateral-g.net/forums/showthread.php4?t=28606
Old 02-22-2011, 06:30 PM
Jon Clough's Avatar
Jon Clough Jon Clough is offline
That is the best rear suspension IMHO, even if you have to cut a little off the seat.
